Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: I am having trouble doing roofing » » » » Post: Re: I am having trouble doing roofing |
Print at Sep 29, 2026, 4:38:23 AM |
| Posted by Keet at Mar 24, 2025, 6:00:27 PM |
Re: I am having trouble doing roofing Plugins are are stored in the home directory in a subdirectory named '.eteks' (that is on Linux, on other systems probably something similar and it's a hidden directory so check that these are visible). Under that directory there is a subdirectory sweethome3d/plugins. Just backup the files in that directory. Actually, only the plugin manager plugin is necessary since with that plugin it is easy to install the other plugins. With the boxes: if grouped they should all resize with the same percentage, not with a fixed number. Make sure you select the group and not the individual boxes. If that doesn't work you can use the resize function. I think it's a feature of the advanced edit plugin. And if THAT still doesn't work you can select all boxes and export/import them. Then the group is a single object that should resize as one. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 29, 2026, 4:38:23 AM |
