Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Can not save » » » » Post: Re: Can not save |
Print at Oct 1, 2026, 2:33:29 AM |
| Posted by hansmex at Jul 3, 2010, 1:16:52 PM |
Re: Can not save Bandit: If you use the online version, you will have to register first and login to your account before you can save your design. There is a clear message above the working area that says so. If you haven't created an account, or if you haven't logged in, you have a problem, because in both cases you will lose your work. If you always work with your laptop, you may consider using the installed version from the Download Section. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
Current timezone is GMT Oct 1, 2026, 2:33:29 AM |
