Print at Sep 14, 2026, 8:09:43 AM
Posted by Keet at Feb 15, 2025, 3:42:27 PM
Re: Copy saved view
For me (on Linux) it works as I decribed. I use the same method to update version numbers in furniture library property files (a furniture library .sh3f file is also a zip file).
You can first try to rename the .sh3d to .zip. Maybe that solves the readonly problem if you are sure the file is not readonly. Maybe it's in a directory where you can't edit?
If that doesn't work then you can extract the whole file in a directory. Update and save the Home.xml file. Select all files in the directory and create a new zip file. Change the extension from zip to .sh3d and you're done.
