Print at Sep 20, 2026, 7:39:15 PM
Posted by AeowynFraser at Feb 8, 2025, 2:21:29 AM
Re: A house I've been working on (Tudor) redesigned
I think I've got the new version of this house pretty much updated (well, until I think of something else to add?), and new photos rendered. The house now has a total of five bedrooms, four bathrooms, and a couple of other new rooms. Without further ado, here are the pictures.
Disclaimer: I did not add window coverings inside the house, and in some rooms I did not add wall art. It is to be assumed, and imagined, that these things are there.
I am, of course, starting with the outside front:
And, as you walk in, on the main floor, you'll see that there aren't all that much in the way of changes (mostly cosmetic), except in the garage:
Now, the second floor, starting with the hallway starting from the stairs:
The bathroom and bedroom closest to the stairs, as well as the laundry room, haven't changed much. The biggest change, with the laundry room, is that I took out the door frame and replaced it with a door.
What I'd previously had as the family room, I've made into one of the new bedrooms, with a small walk-in closet:
The new family room, where one of the original bedrooms had been:
Now, onto the new rooms added above the enlarged garage, starting with the new bathroom:
The first of the new bedrooms, with a walk-in closet:
And, before heading to the top floor, here's the second of the new bedrooms:
Top floor, starting with the sewing/craft room, and not much changed here:
The rest of the rooms have been changed quite a lot, including the addition of the following sitting room:
The revised primary bedroom, and its en suite bathroom (I didn't get a picture inside the large walk-in closet, which also has a door to the sewing/craft room):
Now, the outside back. Not much changed here, just adjusting for the larger garage, and the back fence/gate separating the patio area from the green space.
Finally, the screenshots of each level of the floor plan:
And, before I forget, here's a link to the file if you wish to download it.
