Print at Sep 20, 2026, 2:44:00 AM
Posted by Keet at Jan 24, 2025, 7:15:18 PM
Re: A way to make any model in the correct sizes
I use that box trick very often! Works great, just like you described.
A little addition that might be helpful in some cases:
You can modify the measuring box and check "Part of base plan". Then lock the 2D view with the little lock in the top-left corner. Now the box is fixed in the plan and you can draw over it without accidentally selecting the box itself.
When done unlock the plan and you can remove the box.
