Print at Sep 20, 2026, 11:53:51 AM
Posted by GaudiGalopin3324 at Jan 24, 2025, 8:00:12 AM
rose   A way to make any model in the correct sizes
There is a basic size for each item in the interior, which must be carried out very carefully. For example, a chair. They come in three types. A simple low chair at the dining table, a medium bar stool at the kitchen counter, and a high bar stool at the bar counter. In chairs, the most important size is the height of the seat. The low chair is 47 cm for a 75 cm table. The average chair is 63 cm for a table of 90-91 cm. 75 cm high chair for 103 cm table. Usually, the model comes in curved sizes and it is unclear how to make it in the interior correctly. First, determine the width and length of the chair. To do this, find a similar model in the drawing on the Internet. Now make a template from a bright-colored box with a width of 10 cm and a height of 47 cm, place this template on the edge of the chair. And now, using this change tool, pull out the entire chair according to the template. In this way, you can make three different types of chairs from one model for different occasions.
But pay attention. Chairs 1 and 2 were high bar stools at first, they make all the other lower versions work well because the backrest is getting smaller, but this is normal, there are such designs of chairs with a low backrest. But if the chair is low at first, then the backrest increases disproportionately in other types, the chair becomes disproportionate because of the backrest (number 3). Therefore, it is better to make changes from high bar stools rather than the other way around.
