Print at Sep 13, 2026, 10:41:08 PM
Posted by GaudiGalopin3324 at Jan 4, 2025, 12:09:02 AM
Re: Can light be dimmed at its source (or can the source be removed) w/o losing the effect of light?
it seems to me that you need to master the basic export and import skills here. First, export to OBJ. This is done with these buttons.
Select everything you need to export and click on "Export in OBJ format" in the "3D View" column at the bottom. Then do the "furniture import" and drag the OBJ file from the downloads to the import window. And there, rotate the model vertically using the arrows (as in the picture above). You don't need to turn anything off!
