Print at Sep 24, 2026, 3:11:51 PM
Posted by k005 at Jan 3, 2025, 6:24:34 PM
Re: Generate roof plugin
Maybe it will help you find it...
In this code, the area of ​​each triangular surface of the 3D surface is calculated by Heron's formula.
This formula helps you find the area of ​​the surface with the side lengths of the given triangle.
Heron's Formula:
If the side lengths of a triangle are aa, bb and cc, the area AA is calculated as follows:
Here, ss is the half perimeter of the triangle and is calculated as follows:
