Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Can light be dimmed at its source (or can the source be removed) w/o losing the effect of light? » » » » Post: Re: Can light be dimmed at its source (or can the source be removed) w/o losing the effect of light? |
Print at Sep 14, 2026, 1:06:06 AM |
| Posted by Keet at Dec 27, 2024, 10:37:49 PM |
Re: Can light be dimmed at its source (or can the source be removed) w/o losing the effect of light? Really? I didn't realize that would work. That's good to know. Thanks! Unfortunately I don't believe it would work here because that diagonal roof panel is also arced at 7% to accommodate the arced outer wall, and I know that any arc at all causes a problem with doors and windows. You advised me about that with an earlier question I had. With an arced wall that wouldn't work, only with a straight wall. From your image I thought the angled roof part with the windows was straight. A 7% arc is difficult to see on a flat image. If you could keep the part with the windows straight you could still try the window-in-wall method, otherwise you're out of luck.By-the-way, that would mean that your windows also have a 7% arc? ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 14, 2026, 1:06:06 AM |
