Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Export to HTML5 plug-in » » » » Post: Re: Export to HTML5 plug-in |
Print at Sep 6, 2026, 5:20:53 AM |
| Posted by Puybaret at Dec 14, 2024, 1:41:35 PM |
Re: Export to HTML5 plug-in @vlycop You must use a plug-in which uses some data that the plug-in may not be able to handle. @Keet In project SweetHome3DJS, you should remove the lines 375 to 391 in build.xml and run Ant viewerBuild target. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 6, 2026, 5:20:53 AM |
