Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Can’t get my obj. files to connect with textures in the mtl. Files. » » » » Post: Re: Can’t get my obj. files to connect with textures in the mtl. Files. |
Print at Sep 15, 2026, 8:05:22 AM |
| Posted by Keet at Dec 12, 2024, 6:25:00 PM |
Re: Can’t get my obj. files to connect with textures in the mtl. Files. The texture mappings in the mtl file (map_*) are ones that are not processed by Sweet Home 3D. Remove these lines from the mtl file: map_Ns C:/Users/Sir Thomas/Desktop/tng-hypospray-original-sternbach-design/textures/DefaultMaterial_Roughness.pngand add the line map_Kd DefaultMaterial_Base_Color.pngresulting in newmtl Material.001The object is very small when you import it. It seems like width and depth are 0 and the height is 0.1. Modify it and check "Keep proportions". Set the height to 10 or 15 and the width and depth will adapt proportionally. ETA: It's good practise to place the texture files in the same directory as the obj and mtl files. That way you don't need a path in the mtl file. A path can make the file unreadable on a different system. On top of that the current set path (a user directory) doesn't exist on someone elses computer. And about the map_* lines: "map_Kd" is the only texture mapping recognized by Sweet Home 3D. You can view the texture files and choose the one that offers the most "normal" texture. In this case that was the image DefaultMaterial_Base_Color.png. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 15, 2026, 8:05:22 AM |
