Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Help creating new object & light source from scratch » » » » Post: Re: Help creating new object & light source from scratch |
Print at Aug 20, 2026, 2:37:43 AM |
| Posted by Keet at Dec 2, 2024, 6:21:40 PM |
Re: Help creating new object & light source from scratch I'm in my file right now but I can't see any way to alter the thickness of a floor. It only has an area to change thickness for the optional baseboard, which I didn't want or need on the light. Under Preferences I see an option to change the new level floor thickness, but but that doesn't seem to be what I want. I'm trying to modify the floor in the initial stage where I first created it. I also tried modifying it after I exported, and then imported it back into the program, but at that point, it's part of the whole object and the brace was already set for 6" thickness. What am I doing wrong here? You set the floor thickness on the level. Double click the level tab and you can set the floor thickness. If you don't see a level tab or can't set the floor thickness just add a level and set its elevation to a negative value. Now you can double click the level where your floor is and set the floor thickness. Export/import only your floor object. Now it has a thickness you can adjust to your 6".Wait, so if I made the color of those panels bright red, I'd get a red light? It makes the color and surface of the panel automatically translucent? When I've been working with the light panels, when I rotate them a certain way, when I get to the opposite side of them, they often disappear or turn invisible, so I assumed that whatever 'color' I assigned them was just replaced by whatever the program uses to represent illumination? Yes, you would get a red light. But it doesn't change transparency so it doesn't become translucent. Your panel was created with a room with floor thickness 0 which means it only has one face (side): the top. If you rotate it the other side is simply 'nothing'.When you export the floor with a thickness (set the level floor thickness before export) it will have 6 sides after import. All with the material name room_1_1. This means that you automatically have a light panel for both sides after you placed it in the brace. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Aug 20, 2026, 2:37:43 AM |
