Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Bug? No lightSourceMaterialName when Door or window » » » » Post: Bug? No lightSourceMaterialName when Door or window |
Print at Sep 20, 2026, 1:22:01 AM |
| Posted by Keet at Nov 18, 2024, 1:19:41 PM |
Bug? No lightSourceMaterialName when Door or window I ran into an unexpected problem with a window where I wanted to assign the lightSourceMaterialName property to a part of a window. The problem is simple: you can't set the property in the Furniture Library Editor when the object is a Door or window. I tried to cheat by manually adding the lightSourceMaterialName property in the library properties file but of course that didn't work. I can't think of any logical reason why this shouldn't work for a window. For a staircase it does work. I tried it, the library property is available and there's a power property when you modify the staircase. A lighted side panel looks good in a render! Is there a reason why this doesn't work for a window or is this a bug? ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 20, 2026, 1:22:01 AM |
