Print at Aug 20, 2026, 2:39:35 AM
Posted by Keet at Nov 8, 2024, 7:40:11 PM
Re: Help creating new object & light source from scratch
Since you used walls to create the form of the brace you can just select the Create room function on the toolbar and double click in the open space of the brace walls. It will create the room completely filling the space.
Modify the room: select the Select objects arrow on the toolbar and double-click the room. A room consists of two parts: the floor and the ceiling. For your purpose you only want the floor so uncheck the "Display ceiling" checkbox.
(I'm not sure what dialog you got but the Modify Rooms dialog doesn't have a section for baseboards, that's a property of walls.)
With the room now drawn you can continue with the process I described before.
