Print at Aug 20, 2026, 4:48:04 AM
Posted by Wendell_Burke at Nov 7, 2024, 9:51:50 PM
Re: Help on angled doors please?
Unbelievable. So I do think that selecting only the objects i want before exporting to Object was a part of it, as was importing it and remembering to switch it to a Door or Window, which I did, but I'm getting mixed results. I am working from a few open files at once.
One is the whole room that I've been building and slowly adding things to. When I installed the new door in the wall of this file, it didn't work, as you can see by the red circles in the attached image.
The other file was a new one just to build the door in, again, from scratch. I usually export it as an object, then Import is into the Furniture library of 'User'. THIS time, in this working file for the door, I created a simple wall, not even a whole room or floor, and as you can see, it worked!
What I can't figure out is why can't I make that happen in my other cabin file?
https://www.dropbox.com/scl/fo/6hnomrps9pkphv...&st=yqneyh7m&dl=0
