Print at Aug 20, 2026, 1:39:51 AM
Posted by Wendell_Burke at Nov 7, 2024, 5:57:11 AM
Re: Help on angled doors please?
Shoot. It keeps happening. I went back and deleted the other files I had for the door and rebuilt it from scratch, changing it a little in the process.
I did import the door and checked "Door or window" in the import dialog.
As I mentioned, I started over from scratch and I can't find any small bits of wall or anything in the corners when I built or saved the file. Here's a pic of the latest attempt.
https://www.dropbox.com/scl/fi/0fqetvolk929un...&st=mmj9v5tg&dl=0
I'm not sure I understand what you mean by 'close the bottom' but I did create another wall at H:3" with a Thickness of 1/8" because I thought that might make that part disappear at the bottom of the door. I then went around each part of this doorframe and joined any walls that I could.
I didn't try your suggestion yet because I had a question about it; Is there a difference between building with a wall and a shape like a box or a triangle? I made another object for this project and most of it is made out of walls but I noticed the part that wasn't stands out with a different kind of finish even though it appears to be all in one default color when I check.
Any thoughts?
