Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Help on angled doors please? » » » » Post: Re: Help on angled doors please? |
Print at Aug 20, 2026, 5:39:50 AM |
| Posted by Keet at Nov 6, 2024, 5:32:57 PM |
Re: Help on angled doors please? Did you import the door and checked "Door or window" in the import dialog? If you didn't that might solve the problem. If you did the object is actually rectangular, in other words, there is something in the corners instead of empty space causing the hole to be rectangular. It is also possible that you didn't close the bottom of your door. Add a sill so the outline of the door is a closed form. You can check how this works: Drag a triangle into your 2D pane and turn it so the slope is on the right or the left. Select and export the triangle. Import it and check "Door or window" in the import dialog. The triangle now is a door. Drag it into a wall and it will create a triangle hole and the depth of the triangle will become the same as the wall thickness. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Aug 20, 2026, 5:39:50 AM |
