Print at Aug 20, 2026, 8:59:28 AM
Posted by Keet at Nov 6, 2024, 3:22:12 PM
Re: Help on angled doors please?
It's not completely clear what you want to create. I understand you want a hole in the wall with the same angles as the door and then have that door sliding (in?) the wall? Or in front of the wall like barn doors? And do you want the door to slide with a deformation on a rail?
Basically you get a rectangular cutout because the outline of your door object is rectangular. Create door posts around the door with the same angles and nothing else sticking out. Or add the door to a furniture library where you can set a custom cutout. Warning: this is not the easiest model for someone just beginning with Sweet Home 3D but it can be done.
The image you tried to display is a link an image on your local drive, that doesn't work. Upload it to an image host like mediafire or imgur and use that link in your post. Maybe the image makes it clear what you want to achieve.
