Print at Sep 10, 2026, 8:18:48 PM
Posted by scjo at Oct 30, 2024, 11:51:11 PM
Re: (Semi)transparent Mirrors
It works:
The mirror is 70% transparent. You may try different transparencies using the source images. With Image Magick installed, compositing is a simple command:
In reality, the scene behind the mirror would be quite dim, and the transparency much lower, maybe 15%. That makes it harder to look through from the front and accommodates the observer behind to the little amount of passing light.
The mirror leans 1° away from us. Therefore the mirrored horizon is 2° below the one in direct view.
Cheers - Joe //
