Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Couldn't attach tecture with correct dimension to imported OBJ file (not *.mtl error) » » » » Post: Couldn't attach tecture with correct dimension to imported OBJ file (not *.mtl error) |
Print at Aug 17, 2026, 3:43:09 PM |
| Posted by Kigler at Oct 16, 2024, 12:35:27 PM |
Couldn't attach tecture with correct dimension to imported OBJ file (not *.mtl error) Hello! I use the follwing version: 7.5.1 from Microsoft Store I could import *.obj file with texure, it works well, but i have problem when i would like to modify the texures in the Sweet Home 3D I made the furniture 3D models in Autodesk Inventor and exported them to OBJ files. I didn't set (in Autodesk Inventor) a texture for some of the furniture because my plan was to change the different textures on them in Sweet Home 3D to find the one that suits them best. My problem is that the texture size does not fit the objects, as if the texture is much, much larger. I am attaching a picture of the settings. Imported OBJ Then I tried to use an built in/original texture, what is 30x30cm. You could see the setting and the result in the following picture Builtin texture My obj file is the following: OBJ file should I use a program other than Autodesk Inventor? Thanks You for your help! |
Current timezone is GMT Aug 17, 2026, 3:43:09 PM |
