Print at Sep 23, 2026, 1:39:49 PM
Posted by db4tech at Jun 18, 2010, 5:19:52 PM
Re: Increase memory
Since we know that -Xmx1024m works on Windows 7 and makes a drastic render speed difference, I have now tried the same 1GB on an XP virtual machine with 2GB of memory for you and Sweet Home started straight away.
I can set up a Vista virtual machine and test that if it's helpful?
Could the problem you encountered before be because the users computer had 1GB or less system memory? If so would the idea of a line of code to check the computers base memory before setting -Xmx1024m work and solve the previous problem?
PS: Do you have any ideas why it doesn't make a lot of difference with the Uber shader at the moment.
db4tech
