Print at Sep 26, 2026, 1:51:11 PM
Posted by Keet at Sep 30, 2024, 1:21:24 PM
Re: How do I set the exact coordinates of a room?
When you select a room the corner points of the room become visible. You can drag those points to the wall corners and a larger dot will appear when it is snapped into the corner. (This is of course with magnetism on.)
You can also select the room, right click it, and from the context menu select "Recompute room points". This will redraw the room and is especially convenient when you have moved doors. This will recalculate the room around the doors.
