Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Countertop Cutouts » » » » Post: Re: Countertop Cutouts |
Print at Sep 24, 2026, 1:05:41 AM |
| Posted by Keet at Sep 24, 2024, 1:06:49 PM |
Re: Countertop Cutouts The easiest way is to use a wall for your countertop. First tilt your sink so the top points forward. Export the sink. Import the sink and check "Door or window" in the import dialog. Create a wall as if you have your counter top standing on its front side. Insert your import "window-sink" in the wall and adjust its position and elevation. It will create a hole in the wall the size of your sink. Only select the wall and export it as countertop.obj. Import it and tilt it back so it is horizontal again. Export/import and you have your countertop with a hole for your sink. A little tip: If your sink has a small border you should make the sink a little smaller before export and import as a window. This will make the hole a little smaller so it stays under the border of your original sink. Check the manuals page on dodecagon.nl for a manual on how to change material names. A material "Top" looks better than "wall_1_1" if you want to set the color or texture of your countertop. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 24, 2026, 1:05:41 AM |
