Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: How to replace glass with non-transparent material? » » » » Post: Re: How to replace glass with non-transparent material? |
Print at Oct 6, 2026, 10:03:45 AM |
| Posted by Keet at Sep 14, 2024, 11:00:14 PM |
Re: How to replace glass with non-transparent material? Do I need to edit the underlying model? Yes. Export the model. This will produce two files an .obj, and a .mtl file.Edit the mtl file. Search for the block that starts with "newmtl" followed by the name of the glass as you saw it when you modified the model in Sweet Home 3D. This block will have a (last) line starting with "d" followed by a number < 0. Either remove the d line or set the value to 1.0 to remove the transparency. Save and import the model again by dragging the .obj file into your 2D pane. Remember to check "Door or window" in the import dialog if you want the model to act like a door that snaps into a wall. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Oct 6, 2026, 10:03:45 AM |
