Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Imperfect rendering » » » » Post: Re: Imperfect rendering |
Print at Aug 24, 2026, 6:58:53 AM |
| Posted by db4tech at Jun 12, 2010, 6:25:30 PM |
Re: Imperfect rendering db4tech, I found where this wrong effect comes from. I would be glad to publish a plug-in with the fix but there's still a problem with sunlight that doesn't reflect on walls. ![]() Hi Emmanuel, With you now working on Sweet Home version 2.5, is this something that could be added (even though sunlight doesn't reflect) or is it something to add to the shader plug-in's? If it is a shader addition, knowing that renders will take longer to calculate, will you be able to add a render quality slider (like the inbuilt photo render) so a user can choose to render with or without indirect illumination? Having indirect illumination (even without sunlight reflection) with maybe only 1 or 2 ray bounces will make a dramatic effect, further enhancing the realism of final renders. I am very happy to test this for you! ![]() One last request, when you do finally replace the inbuilt render with one of the advanced renders please keep the most basic render (like the inbuilt Create photo... Fast render) I find this setting very useful (creating an almost instant render) to see what will appear in a final render when trying different camera positions, angles and aspect ratios, before doing a full render. Thank you for your time. Hope you are having a great weekend! db4tech |
Current timezone is GMT Aug 24, 2026, 6:58:53 AM |
