Print at Sep 29, 2026, 6:38:10 AM
Posted by SWEETMAN3D at Aug 28, 2024, 8:14:01 PM
curtain problem (sweethome 7.5 version)
i have installed the latest version SweetHome3D-7.5-windows (64bits) but the problem with the curtains continues.
now its no longer just a transparency issue, it seems be a rendering problem.
i searched the forum and found the following solution.
change its transparency setting in the MTL file used with the OBJ file you imported (if it's not the case export it to OBJ format). The transparency factor of a material is set on a line starting by d (0 for fully transparent to 1 for opaque).
that's what i did
i then imported the object into my library and attached it to the house plan.
then when exporting the image both in sunflow and yafaray the problem appears.
the transparency is gone but the rendering still adds that intense sheen on an object that's clearly made of fabric and not plastic.
some points to mention:
1. shininess is at Matt (0)
2. i even tried dark colors but the problem still continues
3. i also tried using other textures from the library on the curtain but did not get any solution.
i hope that some developer will pay attention to this problem, i would like to find a solution
