Print at Sep 29, 2026, 4:35:12 AM
Posted by lybin at Aug 28, 2024, 7:52:47 AM
Re: Artifacts on imported models in plan view
I've install newer jre-openjdk 22, it was 8.
On the first try the app requires sharing screen and stucks. If to kill and try import again it success.
lev@lybin ~ $ sweethome3d
WARNING: package com.apple.eawt not in java.desktop
WARNING: package com.apple.eio not in java.desktop
Java 3D: implicit antialiasing enabled
Exception in thread "AWT-EventQueue-0" java.lang.SecurityException: Screen Capture in the selected area was not allowed
at java.desktop/sun.awt.screencast.ScreencastHelper.checkReturnValue(Unknown Source)
at java.desktop/sun.awt.screencast.ScreencastHelper.getRGBPixels(Unknown Source)
at java.desktop/sun.awt.X11.XRobotPeer.getRGBPixels(Unknown Source)
at java.desktop/java.awt.Robot.createCompatibleImage(Unknown Source)
at java.desktop/java.awt.Robot.createScreenCapture(Unknown Source)
at com.eteks.sweethome3d.swing.ModelPreviewComponent.getIconImage(Unknown Source)
at com.eteks.sweethome3d.swing.ModelPreviewComponent.getIcon(Unknown Source)
at com.eteks.sweethome3d.swing.ImportedFurnitureWizardStepsPanel.getIcon(Unknown Source)
at com.eteks.sweethome3d.viewcontroller.ImportedFurnitureWizardController.getIcon(Unknown Source)
at com.eteks.sweethome3d.viewcontroller.ImportedFurnitureWizardController.finish(Unknown Source)
at com.eteks.sweethome3d.swing.WizardPane$7.actionPerformed(Unknown Source)
at java.desktop/javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at java.desktop/javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at java.desktop/javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at java.desktop/javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at java.desktop/javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at java.desktop/java.awt.Component.processMouseEvent(Unknown Source)
at java.desktop/javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.desktop/java.awt.Component.processEvent(Unknown Source)
at java.desktop/java.awt.Container.processEvent(Unknown Source)
at java.desktop/java.awt.Component.dispatchEventImpl(Unknown Source)
at java.desktop/java.awt.Container.dispatchEventImpl(Unknown Source)
at java.desktop/java.awt.Component.dispatchEvent(Unknown Source)
at java.desktop/java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.desktop/java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.desktop/java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.desktop/java.awt.Window.dispatchEventImpl(Unknown Source)
at java.desktop/java.awt.EventQueue.dispatchEventImpl(Unknown Source)
at java.desktop/java.awt.EventQueue$4.run(Unknown Source)
at java.base/java.security.AccessController.doPrivileged(Unknown Source)
at java.base/java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source)
at java.desktop/java.awt.EventQueue$5.run(Unknown Source)
at java.desktop/java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.desktop/java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.desktop/java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.desktop/java.awt.WaitDispatchSupport$2.run(Unknown Source)
at java.desktop/java.awt.WaitDispatchSupport$4.run(Unknown Source)
at java.desktop/java.awt.WaitDispatchSupport.enter(Unknown Source)
at java.desktop/java.awt.Dialog.show(Unknown Source)
at java.desktop/java.awt.Component.show(Unknown Source)
at java.desktop/java.awt.Component.setVisible(Unknown Source)
at java.desktop/java.awt.Window.setVisible(Unknown Source)
at java.desktop/java.awt.Dialog.setVisible(Unknown Source)
at com.eteks.sweethome3d.swing.WizardPane.displayView(Unknown Source)
at com.eteks.sweethome3d.viewcontroller.WizardController.displayView(Unknown Source)
at com.eteks.sweethome3d.viewcontroller.FurnitureCatalogController.importFurniture(Unknown Source)
at com.eteks.sweethome3d.viewcontroller.HomeController.importFurniture(Unknown Source)
at java.base/jdk.internal.reflect.DirectMethodHandleAccessor.invoke(Unknown Source)
at java.base/java.lang.reflect.Method.invoke(Unknown Source)
at com.eteks.sweethome3d.swing.ControllerAction.actionPerformed(Unknown Source)
at com.eteks.sweethome3d.swing.ResourceAction$AbstractDecoratedAction.actionPerformed(Unknown Source)
at java.desktop/javax.swing.AbstractButton.doClick(Unknown Source)
at java.desktop/javax.swing.plaf.basic.BasicMenuItemUI.doClick(Unknown Source)
at java.desktop/javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(Unknown Source)
at java.desktop/java.awt.AWTEventMulticaster.mouseReleased(Unknown Source)
at java.desktop/java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.desktop/java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.desktop/java.awt.EventDispatchThread.run(Unknown Source)
*** pw_stream_disconnect called from wrong context, check thread and locking: Operation not permitted
*** impl_ext_end_proxy called from wrong context, check thread and locking: Operation not permitted
'this->recurse > 0' failed at ../pipewire/src/pipewire/thread-loop.c:62 do_unlock()
Maybe it's related to Wayland?
What the Java version is preferred? I can adjust the package in Archlinux.
