Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Furniture Library Editor released » » » » Post: Re: Furniture Library Editor 2.2 |
Print at Oct 5, 2026, 8:03:31 PM |
| Posted by Keet at Aug 22, 2024, 10:42:19 AM |
Re: Furniture Library Editor 2.2 Keet, I couldn't reproduce your issue about columns size in the editor. Maybe it's due to the Java version you use. Do you mean that when you open a library in the editor all columns are resized according to their content?I don't think it's a java version problem. I changed my start script for the editor to specifically use the same version as supplied with Sweet Home 3D. That doesn't make a difference. The trick with opening the preference dialog and closing with OK works the same, all columns perfectly resized. I'll keep using that trick. Or did you mean the tiny column divider for resizing? That is not a java version problem, that is my old age working against me Thank you for fixing the lightSourceMaterialName bug. No more manual editing to fix it after I edited a library! ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Oct 5, 2026, 8:03:31 PM |
