Print at Aug 24, 2026, 6:59:09 AM
Posted by Puybaret at Jun 11, 2010, 12:39:23 AM
Re: Option to replace furniture
Instead of a adding a menu, the furniture modification dialog could show the 3D model of the edited piece and a list to choose an other one.
The default thickness is 7.5 cm simply because it's the thickness of the partition walls in my home. As the thickness of exterior walls may vary a lot from one home to the other, I preferred to use that value as a default.
I wouldn't mind to change this value but I don't believe that increasing it would help to create larger rooms. A tip showing the squared value of the current length (or the result of multiplying the current length with the length of the previous wall when it exists) would probably help more users, because I think most people know the standard surface of rooms as soon as they moved once (for example, in France flats, bedrooms are around 10 m², a living room is most of the time between 10 m² and 25 m², a kitchen between 5 m² and 10 m²).
