Sweet Home 3D Forum » List all forums » » Forum: Gallery » » » Thread: Apartment project with lighting by invisible hemispheres. I continue advertising » » » » Post: Re: Apartment project with lighting by invisible hemispheres. I continue advertising |
Print at Sep 20, 2026, 4:34:26 PM |
| Posted by GaudiGalopin3324 at Jul 1, 2024, 4:42:55 PM |
Re: Apartment project with lighting by invisible hemispheres. I continue advertising I prepared the water in online Photoshop, cleaned the background in each frame (there were 61 pieces) as much as possible, set the transparency of all frames to 25%, made two variations with color - light green, and a denser blue. Such a different color gives the water a play, it looks more lively, shimmers a little like a real one. I made two tracks with different colors, and superimposed the first most complete animation on top of each other without offset. Then I copied and cut off a small piece of smooth water from each part. Changed the video speed of these pieces to 45% and 50%. And I scored 13-14 pieces in a row of such pieces. The boundaries between these pieces were made with an overlap of 1 second so that there would be no sudden jumps in the video. Due to the fact that the speed of the waterfall sections is slightly different, the overlap turned out to be without visible sharp repetitions, the water flowed really!)) Without cycles. these are tracks No. 11 and No. 9, they connect into a stream of living water. I showed the difference in the speed of these pieces in different arcs. once again, the final video file is here https://www.mediafire.com/file/w5dn3v8jkpu536...25BC%25D0%25B8_3.avi/file |
Current timezone is GMT Sep 20, 2026, 4:34:26 PM |
