Print at Sep 21, 2026, 9:42:04 PM
Posted by Keet at Jun 27, 2024, 1:22:31 PM
Re: Visibility between levels in plan view
In the 3D view you should be able to see through the hole at what is beneath it. In the 2D view you only see what is on lower levels if the object height is such that the top reaches the current level. For example walls at the correct height show a light grey outline on the level above it.
Add an object on level 0 that has a height of 50. You will see that is shows in the 2D view when you are on level 1. Decrease its height to 20 and you will not see it from level 1.
