Print at Sep 29, 2026, 4:36:02 AM
Posted by Keet at Jun 26, 2024, 10:06:31 PM
Re: Negative elevation floor not visible
With "Display selected level" you see that level and visible levels below it.
But your numbers for the bottom levels are not all correct which might skew your view. If your floor thickness of level 0 is 20 your level -1 with a heigth of 240 should have an elevation of -260 (-(240+20)). That is assuming you want level -1 to seamlessly touch level 0.
Check this manual about levels: Levels Explained
