Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Dark Mode » » » » Post: Re: Dark Mode | Some impressions Beta-1 |
Print at Oct 5, 2026, 4:14:14 PM |
| Posted by Keet at Jun 15, 2024, 11:38:42 PM |
Re: Dark Mode | Some impressions Beta-1 I think (rarely) it is easiest to correct the theme than to modify 100+ applications. That's the right opinion. I ran into this when I was trying to set this up. I stopped when I discovered that every program affected needs a special version. That will completely ruin the updates through the plugin manager unless there is maintenance for two different versions. That is not going to happen and rightfully so. A theme has to work on unchanged applications and only affect the display. It should not depend on what monitor(s) I have. That would mean changing code/settings with every monitor change and for every individual user. Basically I want a dark theme changing the color palette. Not bigger/smaller fonts or icons, only colors. I'm going to look into that but I'm incredibly busy at the moment.No offense, it is only my wrong opinion. Still, this looks very good so we'll see where it goes. A simple drop-in of a theme file as intended is the best result we can hope for. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Oct 5, 2026, 4:14:14 PM |
