Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Library for metal construction objects » » » » Post: Re: Library for metal construction objects |
Print at Sep 21, 2026, 4:24:31 AM |
| Posted by Keet at Jun 11, 2024, 1:23:40 PM |
Re: Library for metal construction objects You guys think to complex for a simple I-Beam If I had to create it 100% in Sweet Home 3D I would do it like this: Draw the walls like previously shown but make sure that the inside of the walls measure as what the I-Beam must be. Create a room inside the walls. Export the room and after import stretch it to the required height. Done. One I-beam with an object size of 7.5kB. The only problem is that the texturing of the center is diagonal but that could be solved by only using a room to create the top part. Texture, export, import. Copy and flip vertically. Put a box between them for the center. Texture the box before export and after import you have a perfect I beam with nice rounded curves and a minimal object size. And completely created in Sweet Home 3D! ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 21, 2026, 4:24:31 AM |
