Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Dark Mode » » » » Post: Re: Dark Mode |
Print at Oct 5, 2026, 4:14:45 PM |
| Posted by byDMA at Jun 9, 2024, 8:51:45 PM |
Re: Dark Mode Hi Emmanuel, thanks for the quick response and for the praise. The existing ones in reverse video didn't please you? Which video do you mean? I've done some more tests and found out the following: -This has nothing to do with Flatlaf, this is also the case in the old Steel design - It ONLY works if scaling factor is 2, between 1 and 2 this does not change - Scaling is really a bad idea at Latlaf, everything is going to be huge Latlaf (out-the-box) is actually an ideal interface for SH3D, everything is scaled and designed correctly - except for the icons from the plugins :-) Take a look at this: https://disk.yandex.com/d/-qCRHNEioo8tbA I suspect this is the JFrame in the menu(s) for the plugins in SH3D. It frames the icons up to the scaling factor 2. Only then it gets bigger and the icons are enlarged. Could you check it out? This should not be a big problem. Then the design would be perfect. |
Current timezone is GMT Oct 5, 2026, 4:14:45 PM |
