Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Dark Mode » » » » Post: Re: Dark Mode |
Print at Oct 5, 2026, 4:14:24 PM |
| Posted by shadowcaster at Jun 6, 2024, 1:33:50 AM |
Re: Dark Mode Hello Daniels, Thanks for replying. I tried running those commands, but the result is still the same. This was the initial result: PS C:\Program Files\Sweet Home 3D\lib> set SH3DINST="C:\Program Files\Sweet Home 3D"However, with some chatgpt help I ended up with: PS C:\Program Files\Sweet Home 3D\lib> $env:SH3DINST="C:\Program Files\Sweet Home 3D"I tried running this from both inside the sweet home 3d\lib folder and just from C:\. Either way, the end result was running the java -jar command with -dswing again but still not seeing any changes. I did come across another post regarding changing resolution that stated to add an ini file with: -Dcom.eteks.sweethome3d.resolutionScale=1.5and this did work to change the LAF. However, I couldn't figure out how to make flatlaf work in this same way. Note that I did test the above code without this ini file in the sweet home folder to ensure there wasn't a conflict. |
Current timezone is GMT Oct 5, 2026, 4:14:24 PM |
