Print at Aug 19, 2026, 9:37:51 AM
Posted by Keet at May 30, 2024, 9:38:08 AM
Re: X/Y Axis?
@Keet: are you saying I can set one axis, export and import and it's normalised at that position, then set the other axis? As a workaround...
Yes, that is what I do when I need a tilt on both X and Y. I first do one, export, import, and then do the other. It's not perfect because you have to export and import but the result is what you want with both tilts.
