Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Resize entire project » » » » Post: Re: Resize entire project |
Print at Aug 19, 2026, 12:10:25 PM |
| Posted by hansmex at May 27, 2024, 9:49:26 AM |
Re: Resize entire project It's hard to say what you have to do: so many variables, and not much info. Indeed, the AdvancedEditor is the tool to use. WHAT you have to change depends on what is incorrect. Suggestion: make a backup of your plans and work on that file to see what needs to be done. 1 - check height of levels and thickness of floors 2 - check height of walls 3 - check length of walls 4 - check size of furniture (doors & windows are furniture) Where it says "check" you should read "check and if necessary correct by multiplying or dividing by 10". When changing furniture make sure you put a checkmark in "Keep proportions". ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Aug 19, 2026, 12:10:25 PM |
