Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Adding Furniture To Existing Library. » » » » Post: Re: Adding Furniture To Existing Library. |
Print at Sep 9, 2026, 11:06:14 PM |
| Posted by Keet at May 16, 2024, 10:43:36 PM |
Re: Adding Furniture To Existing Library. 1. Export your modified object to obj/mtl if you haven't done that yet. 2. Open the lumber library with the Library editor. 3. Drag the obj file into the library window next to the list. (Or import using the toolbar button). 4. Your object is now added to the library and you should see it as one of the lines in the list. Double click it and you can change the name that should be displayed in the Sweet Home 3D catalog and set the category name to the same as the other objects in the library. 5. Save and exit the library editor. 6. Import the Lumber library in Sweet Home 3D. Choose "Replace" in the import dialog. !important! Be aware that if there is an update from the original library that importing that update will not have your extra object and you will have to add it to the updated library again. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 9, 2026, 11:06:14 PM |
