Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: View in separate window freezes my Mac » » » » Post: Re: View in separate window freezes my Mac |
Print at Sep 13, 2026, 4:21:55 PM |
| Posted by silvanschaad at May 16, 2024, 5:22:23 PM |
Re: View in separate window freezes my Mac Thanks Emmanuel for your reply. I did some more research on second screen behaviour and I looks like this is causing the wheel of death. Fact is that a second monitor is crucial to have because on a 14" macbook I can't work for hours and don't have enough room for details nor overview. So considering this I and your advice, the performance on the macbook without second screen was close to before. Mostly running without any issues no matter what I was doing. I also changed the way I wired up the second monitor. Previously mostly with an external adapter, but now also with the direct html input. I couldn't see a mayor difference though... What brought the solution for now (still testing and observing) is changing the lead monitor within system settings. I had chosen the macbook and changed now to the second monitor which basically solves the problem. So prior to my old setup with an older intel-based macbook this seems to be a newer setting that you can make and that might cause these problems... |
Current timezone is GMT Sep 13, 2026, 4:21:55 PM |
