Print at Sep 15, 2026, 9:59:30 AM
Posted by Keet at May 7, 2024, 11:04:06 PM
Re: Problems with the length of the walls
You can calculate the length you set in the Modify walls dialog like this:
The left and right walls connect to two walls 30cm thick and should be 940 on the outside. Since the length is calculated from the center of the walls your length for the left and right wall is 940-(30/2)-(30/2) = 910.
Your 755cm walls are connected to a 30 cm wall on the left and a 12cm wall on the right so the length in the modify walls dialog is 755-(30/2)-(12/2) = 734.
Basically you add half of the thickness of each the connected walls to get the outside length or subtract half of the thickness of each the connected walls to get the inside length.
Starting with the outside length you subtract half of the thickness of each of the connected walls to get the length value for the Modify walls dialog.
This is just the way Sweet Home 3D handles wall lengths, from the center of the wall. It's the only consistent length value from which you can calculate both the outside and the inside lengths.
