Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Problems with the length of the walls » » » » Post: Problems with the length of the walls |
Print at Sep 15, 2026, 9:59:36 AM |
| Posted by Frunsman at May 7, 2024, 9:47:43 PM |
Problems with the length of the walls Hello, we have a question regarding the length of the walls when connecting four walls together. Our walls have an outer length of 755 cm and 940 cm. The walls with 755 cm each have a thickness of 30 cm. The left wall, measuring 940 cm, also has a thickness of 30 cm, while the right wall, also 940 cm long, has a thickness of 12 cm. When we create it as a rectangle in the program, we are shown dimensions for the outer walls as 776 cm and 970 cm. This is probably because the length refers to the corner points, which are in the middle of the corner. Is there a way to adjust this in the program or to calculate the correct distance for the length of the walls? Thank you for the help! |
Current timezone is GMT Sep 15, 2026, 9:59:36 AM |
