Print at Sep 6, 2026, 6:11:06 AM
Posted by negrito211 at May 31, 2010, 12:06:51 AM
sad   java error (please help)
i am trying to design a house and the best software that i have found thats 3d is "sweet home 3d" of course.for the moment im using firefox i have java installed (see below) but i get an error can someone please help?
when i enter "which java" i get
/usr/local/bin/java
when i enter "java -version"
java version "1.6.0"
Java(TM) SE Runtime Environment (build pxp3260sr3-20081106_07(SR3))
IBM J9 VM (build 2.4, J2RE 1.6.0 IBM J9 2.4 Linux ppc-32 jvmxp3260-20081105_25433 (JIT enabled, AOT enabled)
J9VM - 20081105_025433_bHdSMr
JIT - r9_20081031_1330
GC - 20081027_AB)
JCL - 20081106_01
when i go to the website http://www.sweethome3d.com to try to use the program from my firefox browser i get the following error
Can't start applet:
Exceptionjava lang.Unsatisfiedlinkerror j3dcore-ogl (Not found in java library.path)
why am i getting this error if java is installed? i need java 5 or 6 and i have 6 installed. do i need to create a symbolic link? can some one please help and give me step by step on how to get it working and/or can you help me on how to download and install/compile it? the reason i rather use it for the browser is because i believe if i download it the linux distro im using is a ppc build and not x86.im pretty sure it wont work.if it will can some give me step by step on on to install it. i saw the how to and its to confusing.im using "yellow dog linux" which i believe is "redhat" but i rather use it for the online if you can just help me get java config right sad
thanks
