Print at Sep 20, 2026, 7:10:22 AM
Posted by GaudiGalopin3324 at May 2, 2024, 9:36:48 PM
more about using the photo on the box. I took a photo of a designer clothes hanger on the factory's website. They don't have a 3D model. There is only a photo, in black.
I took this photo, repainted it in Photoshop in terracotta color, cleaned the background. Of course, it was possible to suffer and make a 3d model yourself, there are balls of different sizes and a stick-cylinder at an angle, but I was too lazy))). I placed the new PNG photo on the front of the box, removed all other sides, and set the dimensions of the box as needed for this hanger. On the back of the flat image, I placed a ball of bright color so that it forms a dense shadow behind the base of the hanger. Without this sphere, you get a stupid thin shadow line, not like from a massive ball. The ball is green. so that you can move it and notice where it sticks out in the frame. You can't see the green edge, so it doesn't stick out)). Depending on the viewer's perspective, this box can be rotated, it must be perpendicular to the direction of view.
I put hemispherical caps on the image for illumination. They help to show the shape of the ball more voluminously.
as a result, here is a picture with a hanger on the floor of the desired color. If you twist it behind the viewer and put the green ball behind, then you can't see that it changes position)))). Mindfulness test))
I will tell you about the mirror with a mosaic frame separately
