Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Error 3D rendering » » » » Post: Re: Error 3D rendering |
Print at Sep 14, 2026, 6:10:42 AM |
| Posted by dorin at Apr 25, 2024, 10:03:02 AM |
Re: Error 3D rendering 1. Why you've installed under /opt which is under root system? 2. Why you run it as root? 2.1 This is not recommended to do for any applications which usually have to run by a user! 2.2 Particularly for SH3D is that will create the .eteks properties folder under root and not under /home/[user-name]/ if you run it as root. 3. I don't know from where you have "SweetHome3D123" file and what is inside. It should be only "SweetHome3D". 4. There have to be also "SweetHome3D-Java3D-1_5_2" file. Try to run with this file. 5. If you follow STRICTLY the steps described in user's guide this files need to start SH3D by double click on them. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
Current timezone is GMT Sep 14, 2026, 6:10:42 AM |
