Print at Sep 10, 2026, 12:12:22 AM
Posted by bTal at Apr 23, 2024, 11:42:47 AM
Re: Merging levels from multiple files
Thank you, Emmanuel - that was the option I was attempting to locate! It appears to have worked well... except for highlighting a few mistakes between floors! :)
Any input on whether there a "best practice" for how to address multi-level walls using SH3D?
For example, is it better to always draw the walls of each level separately, even if the outside walls always span both floors, or if you have the occasional room with 2-story interior walls, such as for a 2-story entryway?
Similarly, are there issues to using negative heights, say if you have a garage that is a few feet lower than the main floor of a house? (i.e. you need 3-4 steps to get from the garage to the first floor because of the grade of the lot, etc.)
Thanks!
