Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Generated ground broken on import, regenerate? » » » » Post: Re: Generated ground broken on import, regenerate? |
Print at Sep 26, 2026, 7:12:46 PM |
| Posted by leonidas_o at Apr 6, 2024, 12:27:17 AM |
Re: Generated ground broken on import, regenerate? @Keet hmm that's strange, I can see the images even when looking up this post on my smartphone. Yes, your assumption is correct. I was using "export all". I've tried that, select all and export selected, this works, as the "cut-out-ground" is then not exported. @Puybaret, I've tried to move corners, whole rooms, walls, change wall width etc. Nothing helped here, so right now I've exported all selected. I can live with that approach, the only thing is, I have to create a ground plane, as I mostly created square rooms, which means, there is no floor in between door frames. So I can see through it atm. So what is the difference between, "export all" and select all and "export selected"? Is only the one cut-out-ground plane? |
Current timezone is GMT Sep 26, 2026, 7:12:46 PM |
