Print at Sep 26, 2026, 9:14:07 PM
Posted by Puybaret at Apr 5, 2024, 8:03:25 PM
Re: Generated ground broken on import, regenerate?
I fear it's rather an issue in the way Sweet Home 3D attempts to cut the ground with the room. Sometimes it doesn't work well. I tried so many times to fix this problem, that I'm not sure there's a better solution. Maybe moving a little the corners of the room where you see the issue could help. Anyway, no need to export many times your design to check a fix, because you should see this flickering in Sweet Home 3D too.
