Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Sweet Home 3D 7.3 » » » » Post: Re: Sweet Home 3D 7.3 |
Print at Sep 23, 2026, 12:23:36 PM |
| Posted by Puybaret at Apr 2, 2024, 12:33:19 PM |
Re: Sweet Home 3D 7.3 Thanks for your tests and feedback The regression in the furniture import wizard of the version 7.2 is that a 3D model imported in the plan is added to the catalog even if you keep the checkbox Add to catalog unselected. You have to select then unselect the checkbox again to prevent the imported model to appear in the catalog. As explained in the help, importing a 3D model into furniture catalog or into home depends on whether the catalog has focus or not when you choose Furniture > Import furniture... menu item. If the furniture list, the home plan or the 3D view has focus when you choose this menu, the imported model will appear in catalog only if you check the Add to catalog check box, at the third step of furniture import wizard. The same thing happens if you drop the file of a 3D model onto the furniture catalog or the plan. When you select a single object in the 3D view the keyboard combo ctrl+E works to get the modify dialog but not if you select multiple objects in the 3Dview. I just tried under Windows, macOS and Linux, but didn't notice this issue. It would be astonishing that a plug-in could alter this behavior.The same import should be implemented for import in the next version of the Furniture Library Editor. It will.---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 23, 2026, 12:23:36 PM |
