Sweet Home 3D Forum » List all forums » » Forum: Gallery » » » Thread: Apartment project with lighting by invisible hemispheres. I continue advertising » » » » Post: Re: Apartment project with lighting by invisible hemispheres. I continue advertising |
Print at Sep 20, 2026, 5:42:16 PM |
| Posted by GaudiGalopin3324 at Mar 28, 2024, 11:46:10 AM |
Re: Apartment project with lighting by invisible hemispheres. I continue advertising """"""I assume that the thin contour is around the straight sides of the photo. As I understand it, it is just so that the outline is not transparent because that causes the white line with YafaRay. Right?""""" if you are talking about the outer rectangular border of the field of the processed photo, then it remains without a contour. I am using a 3 pixel contour setting with an EXTERNAL offset, the 3 pixel contour is shifted inside the photo from the selection line. And the outer rectangular frame remains without a contour, because the contour shifts into the void, outward from the field. Is that what you were asking? |
Current timezone is GMT Sep 20, 2026, 5:42:16 PM |
